tinyCam Monitor - Android viewer for Amcrest cameras
alexvas
Post by alexvas »
The best Android app for remote surveillance from Google Play Top developer, tinyCam Monitor, now fully supports Amcrest cameras.
http://tinycammonitor.com/
Youtube promo
https://www.youtube.com/watch?v=czo1WbWQTtk
Amcrest cameras supported:
IPM-721S (h264/rtsp, 2-w audio, ptz, preset, relay, led, motion detection)
IP2M-841 (h264/rtsp, 2-w audio, ptz, preset, relay, led, motion detection)
Features:
- Intuitive interface. See the screenshots to appreciate the quality of the app.
- SSL support (HTTPS protocol) for secured monitoring and encrypting credentials (digest authentication).
- 14 different layouts with unlimited number of cameras.
- Control PTZ (pan-tilt-zoom) enabled devices.
- Relay, LED control for some models.
- 24/7 MP4 video recording (Android 4.3+) on local storage/SD card and JPEGs recording to the cloud (Dropbox, Google Drive, Microsoft OneDrive, Amazon Cloud Drive) and FTP/FTPS server.
- Sequence mode for automatic cameras switching.
- Group cameras by tags.
- Easy to use pinch to zoom for digital zooming.
- Import/export settings to local storage (SD card) or cloud service.
- Very CPU efficient.
Unique features:
- Background recording. Make your own DVR! See https://goo.gl/uQMR60
- Internal web server for remote archive access. See https://goo.gl/V7cKeE
- Both in-app and on-camera motion detection. Make automatic recording or send email on motion! See https://goo.gl/0xr45K
- Face detection.
- LAN scanner for automatic cams detection. Have a camera IP address suddenly changed? It takes couple minutes to fully rescan your home network.
- Audio real-time processing (squelch & alarm) for using it as a baby monitor with audio graph.
- Audio monitoring from multiple cameras at once.
- Multiple background audio.
- Cast to Android Wear. See https://goo.gl/eZgaMt
- Google Cast™ Ready (Chromecast). Video only. See https://goo.gl/g1d8yz
- TV interface.
- Widgets and home shortcuts.
- Floating windows.
- Tasker/Locale automation plugin. See https://goo.gl/lAvDdC
tinyCam Monitor - Android viewer with full Amcrest cameras support
Baby Monitor for IP Camera - iOS viewer with full Amcrest cameras support
shaolin95
Re: tinyCam Monitor - Android viewer for Amcrest cameras
Post by shaolin95 »
Are you the dev?
How exactly do you configure this? I selected the AMCREST but cannot figure out how to make it show.
CameraMan88
Post by CameraMan88 »
Hi,
I'm unable to properly configure tinyCam Monitor and my Amcrest 1080P IP camera to fully work and function properly. Please provide detailed instructions on how to do this.
Thanks in advance.
ISPY
Post by ISPY »
I have TinyCam Pro version 6.5. Foscams work fine, but I can't get my Amcrest cameras to work with it.
alexvas
Post by alexvas »
To get Amcrest cameras to work in tinyCam Monitor be sure you have specified both web (used for ptz and motion detection) and RTSP (used for video) ports in the app.
ISPY
Post by ISPY »
I've opened both ports and I still can't get it to work. I assume the "web" port is the HTTP port?
lmm
Post by lmm »
the default port is 80. but you can only assign one camera to that port. if you have multiple cameras each one will need a different port number. such as 8090 ...
ISPY
Post by ISPY »
I have two cameras, they both have different http and rtsp port numbers. I've opened all four ports on my Netgear X8 router. I can access the cameras via quickDDNS, AmcrestView.com, and the AmcrestView app, but not tinyCam. I had no problems using tinyCam when I was using Foscam cameras, but I just can't get it work with Amcrest cameras.
lmm
Post by lmm »
in TC Pro under advanced settings there is a place for your remote hostname. Do you have the correct remote hostname of your router?
if you type that hostname into your browser hostname:webport can you access the camera?
ISPY
Post by ISPY »
"hostname", does that mean the router's IP address or something else?
