HD 1080P Control software?
hanoixan
Post by hanoixan »
I'm following the online user manual at https://s3.amazonaws.com/amcrest-files/ ... Manual.pdf, but I don't see how to install the same software as shown in the manual. If it means installing the browser plugin at amcrestview.com, I don't see the same interface. It's a much more dumbed-down interface that doesn't let me set the camera up, or format the SD Card, or edit the motion tracking schedule, etc.
The main current problem is that I haven't found an interface (neither iOS or this web plugin) that lets me format the SD Card I've installed into the camera.
Any tips would be much appreciated.
Thanks,
Sean
DavidN
Re: HD 1080P Control software?
Post by DavidN »
Hmm, the web plug in just allows video to be shown through the web browser. It's not a standalone app. Get the feeling of confusion, though. Are you browsing to the camera's IP address? Even with no plugin or video you can still choose Setup, then go to Storage - Destination - SD Card. There's a format button there.
